| Message |
40 mph and above? If it only does it when you stop, it is your fan clutch....If it does it even at speed, than you have a leak somewhere. By the sounds of the puff of smoke, you probably have a bad upper or lower hose from the rad or a coolant line or of course, the water pump. There is 2 small hoses behind the water pump which tend to go also. Are you low on antifreeze? If you are, there is a leak. start car and put a load on it and look at the waterpump to see if it is leaking..Hope this helps...
http://www.members.aol.com/eriksu9/images/1badz.jpg" BORDER=0> ****472 RWHP/461 TORQUE ON 110 RACE GAS @21 PSI ****438 RWHP ON 93 OCTANE PUMP GAS/STOCK MOTOR**** ****429 FT LBS/TQ******************************* Also own: 2001 Harley Davidson Custom Softail Deuce 1997 Ford Explorer XLT V8 AWD 1993 300ZX 2+2 NA 1991 Yamaha YZ250 1985 Ford Bronco 3" lift, 35" Tires Sold: 1986 Yamaha FJ1100 1987 Nissan 300zx na(Z31) 1979 280ZX 2+2 1972 MGB 1968 Pontiac Firebird 1972 Nissan 240Z, dual webber carbs, etc
